Thanks Don Williams
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=3640
Author:  old man [ Thu Oct 27, 2005 2:15 pm ]
Today I cut my first purfling and binding channels using your binding jig. Wow, does it work great!! I have a dedicated porter cable laminate trimmer mounted on it, and I've not used a smoother apparatus in my life. Perfect channels. Thanks, Don, for the inspiration and information.
Author:  Sylvan [ Fri Oct 28, 2005 2:39 am ]
As a preface to this note, I want everyone to know that I have used
literally every binding machine apparatus in my shop. I built the first
"Ribbecke" style binding machine for LMI way back in 1991. I have built,
bought, or tried every other type that I have heard about since then.
None were easy and totally reliable. All had some downside. I finally
settled on a modified version of the "Ribbecke binder" but found that I
had to do much touchup by hand in order to get everything to fit
properly. So that is what I did since 1991. Then, this past weekend, I
finally got around to building Don Williams' design of Harry Fleischmann's
binding jig.
What a revelation! The very first time I tried it on an old guitar I
immediately knew it worked perfectly in much the same way that I knew
the Fox Bender would change guitar making forever. Suddenly I have a
piece of equipment that just flat works. For those reading this post that
have not figured out a way that works for them in binding guitars this is
the way. So, a profound thanks to Don Williams! He has changed the
guitar making community forever with his design!! Thanks, thanks,
thanks!!!!
Author:  LanceK [ Fri Oct 28, 2005 2:48 am ]
Way to go DON!!!!!!!!!!!!!
Author:  Dave White [ Fri Oct 28, 2005 3:44 am ]
Amen to that - Don it's a brilliant design
Author:  JJ Donohue [ Fri Oct 28, 2005 3:45 am ]
That'll make him think about "retiring from retiring"! Congratulations, Don! Nice to know you've made such an impact.
Author:  Don Williams [ Fri Oct 28, 2005 4:08 am ]
Well, let me say thanks, but let me also continue to say that Harry had the idea for the parallelogram portion long before I adopted his design. Thanks Sylvan for pointing that out. I try to give him credit as much as I can. He was the real genius behind the jig.
